Vacuum line of A/C BB - NCRS Discussion Boards
  • Dale C.
    • November 1, 1999
    • 844
    Dale
  • Jeff G.
    • October 25, 2006
    • 187
    Re: Vacuum line of A/C BB
    Dale, I looked at my L36 configuration and took a couple of pictures for you. By-and-large this is an unrestored car. I believe that "Item 1 Cap" is a nylon cap that fits to the AC solenoid which I took a closeup picture of. On the "View B" I have a 3 nipple valve in which 1 is capped. One hose has 1 rib on it and runs to the firewall and the other hose runs to my PB booster. I took a photo of that as well. Let me know if you need more pictures.
    Jeff
    Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
    • Jeffrey S.
      • May 31, 1988
      • 1879
      Jeff,
      Thanks for posting the 2 pictures. It is interesting that the vacuum advance is hooked up to the side port in your lower picture. That port is usually reserved for the AIR pump. The port in front of the carb, which supplies ported vacuum, is usually connected to the Vac. advance. What is attached to this front port on your car? The clip attached to the intake manifold usually handles a metal line. Page 75 of the Dobbins book has a great look at these lines.
      Jeff
      • Dale C.
        • November 1, 1999
        • 844
        Jeff & Jeff
        Jeff G thanks for the pictures, the AIM C60 diagram does not address the pwr. brakes port so it just has the two pickups. It does show the front port of the carb caped so I guess all that metal tubing and valve cover clamping for the non A/C is non applicable. Sure hope someone has a picture of just the basic L36 with C60. Jeff S., what Dobbins book is that that has pictures on page 75. My book page 75 has tires. Is yours the Fact Book of stingray 68 -72? I was mistaken it does have the brake line.
        Dale
        • Jeffrey S.
          • May 31, 1988
          • 1879
          Dale,
          The book you are probably looking at is the Bizzoco "1969 Stingray Guidebook"
          which is the best source for information about '69's out there. Page 75 does indeed deal with tires. The book I'm referring to is the "Fact Book of the 1968-1972 Stingray" by M. F. Dobbins.
          Jeff
          • Dale C.
            • November 1, 1999
            • 844
            Jeff
            This is crazy but I have both of those books and low and behold both page 75's are on tires. It may just be my editions or something. Check yours out. I'll look for the vacum pictures.
            Dale
            • Jeffrey S.
              • May 31, 1988
              • 1879
              Dale,
              I have the 3rd edition (Dobbins). Just go to the section that shows '69 engine pictures and find the first big block photos. You will find the picture I'm talking about.
              Jeff
