Re: 67 break rebuild - do it yourself or not?
Tim, I got them with a complete PB brake package from Zip Products, DB-744. The package included 4 new rotors, Lonestar rebuilt O-ring calipers(very nice), USA hoses, lines, hardware, etc. It was the power brake upgrade kit. Correct PB booster, brackets, and I upgraded the kit to include the CSSB correct reproduction "DC" master cylinder. I also had to purchase new MC-to-front and MC-to-rear brake lines due to the re-located MC. Also replaced all other hard lines, and used DOT 5 fluid since everything was new.
The MC-to-rear brake line was a bit tricky getting in but worked out fine. Hardest part was the most forward clamp bolt under the footwell area. Trick is to use a thin wrench, then cut about 3/16" off of the bolt before you put it back in.
Rich
Rich
