A thread I just read about casting numbers and assembly numbers of C1 Park Lights just made me think of something.....
Assumption:
The typical numbering system has part numbers that end with a even number are for the "right" side(PS), and those that end with a odd number are for the left side(DS).
Is this common for both the casting numbers, as well as assembly numbers when a casting number appears on a part? If a casting # on a part is odd, will the assembly# always be odd, and even# casting always be even assembly #?
..why do I think of these things so early in the morning
Assumption:
The typical numbering system has part numbers that end with a even number are for the "right" side(PS), and those that end with a odd number are for the left side(DS).Is this common for both the casting numbers, as well as assembly numbers when a casting number appears on a part? If a casting # on a part is odd, will the assembly# always be odd, and even# casting always be even assembly #?
