Just purchased a model 10553 Melling oil pump from an eBay seller and I expected it to come with the extra "yellow" spring. Long story short, it wasn't there and the seller doesn't seem to be interested in providing one..even though every other seller on planet earth does. Silly me, I figured it was part of the kit from Melling.
The pump is a VERY nice piece but has the pink spring installed and according to this document, it is a 70 Ib spring. Everything I've read in the archives indicates that my late 63 L76 should have 55 - 60 lbs of pressure. The yellow spring is rated at 58 lbs and seems to be exactly what I need.
My engine is a fresh rebuild and bearing clearances are right at .002 for both the rods and the mains.
Does anyone have experience with the actual pressures obtained using the pink or yellow spring? Debating with myself to determine if I really want to order a new yellow spring and install it. Would I fail a PV with the pink one installed?
thanks,
tc
thanks,
tc
