Re: Melling Oil Pump Spring Pressure
The length of the spring is only part of the equation. The total length of the wire and the diameter of the wire are also important. Also I would be amazed if GM and Melling used the same color coding on pump springs. I think your GM spring is orange because it was made orange. I have a few old GM springs in a can that I removed to put in white springs in the past and they all appear to be orange. We used to do a lot of this in the 60s and 70s. Of course we also would just stretch the stock spring a little to get the same result on occasion.
For example the GM 3814903 spring listed at 2 7/32 length has 21 coils, color code not listed in the parts book. The High pressure spring GM 3848911 has no length listed but is shown as having a white stripe. It is also 21 coils. Obviously it must have a thicker wire diameter and maybe even a longer overall length.
Tom
Tom
I spoke to him last year about the BB oil pickups, the one out of the car with debris was twice the opening of the current melling pick up. Of course they'll try an convince you it doesn't make a difference - but it had to or they would not have made them with the larger openings. Wayne I'd be curious what your pick up looks like, if older perhaps the larger opening?
