Is there a trick way to test the new bulbs I have purchased to make sure they work before installing the cluster. Should I just test each bulb individually with a 12 volt source? Thanks for all replies.
Testing new bulbs before installing 1963 dash cluster
Re: Testing new bulbs before installing 1963 dash cluster
I recently did the same, I just installed all of the bulbsl(I had the cluster out), and then used a ground wire and touched each socket for a few seconds to test them. This checks the socket ground also.
Rich
p.s. If chinese bulbs, extend test time 300%.
- Top
