For a 1956, are the PG kickdown rods that attach to the carb different lengths for the 1x4 carb setup vs. the 2x4 setup?
When I try to attach mine (1x4), just for it to fit the have to let out adjust on the end to almost it's last thread on the shaft. Even then it doesn't seem like the kickdown has all the freedom of movement that it should.
I'm thinking maybe I have a 2x4 kickdown rod that is meant to attach to a rear carb or something...
Thanks!
Thanks!
