I have a 66 350HP that I have trying to get set up correctly with pulleys and belts. I've done a lot of research on this forum and actually have two threads that I started where I got info from others. My car is no A/C and No Power Steering.
I started out with all the wrong pulleys and now have what I believe to be correct based on my research:
Crank Pulley - #3858533. I bought this from GM as it is still available. Got the part number from research on this forum
Water Pump Pulley - #3770245. Got off Ebay and is correct per my research.
Alternator Pulley - #3871242. I have not been able to fine one of these, but I got correct dimensions from two sources and found one in Carlisle that matched the dimensions, e.g. diameter, overall depth, depth from alternator fan to V-Groove, etc. So what I have is withing 1/32" of the original.
Now my probelm - the double groove water pump pulley and double grooved crank pulley line up. Again from research on this forum, the alternator belt is supposed to go on the front grooves, and a captive belt on the rear. However, my alternator belt is a good 1/2" back of the front grooves of the Water Pump and Crank pulleys. I have some pictures attached, but it is difficult to see the issue.
If I move the alternator belt to the rear grooves, it will be better, but still will not line up. Is there anyone out there with a 66 L79 no A/C and no Pwr Steering with a correct pulley setup that I can talk to?
Don
Don
