I have the 4 digit Key No. to my 65 that was on the previous owner's Customer Owner Kit ID Card. I pulled the ignition lock cylinder and it has the same 4 digit code on it, thus it would appear the ignition is the original (?). I have a working key (not original GM) for the ignition which I'm assuming is cut to this code. The key does not work in the doors or glove box. I have no key for those. I'm assuming I will have to pull the door locks and glove box lock out, but will a locksmith be able to "rekey" these cylinders with this 4 digit code? As I've learned here, the ignition and doors will be the same key, but does that key code also identify the glove box/spare tire lock keys. I'm making some asumptions but I would like to keep the keys matching the GM identified key number. I have searched and looked at quite a few threads on keys, but couldn't apply it directly to my inability to totally understand what this 4 digit number meant.
thanks,
Mike
thanks,
Mike
