Transmission tunnel insulation - NCRS Discussion Boards
  • D S.
    • March 1, 2005
    • 1551
    While the drive train is out of the car a friend is replacing the tunnel insulation. The AIM appears to depict the battery cable being installed along the right side of the tunnel wall then the insulation next. A friend thinks the battery cable should be installed inside of the insulation between the insulation and transmission. Which method is correct? Both?
    Scott Sims
    Texas Chapter
  • Paul O.
    • August 31, 1990
    • 1716
    Re: Transmission tunnel insulation
    Scott
    AIM is correct cable then insulation.
    Paul 18046
