I removed the door panels before starting the restoration. They were about the only thing on the car in good condition. I bought and installed the stainless strips that attach to the upper edge of the door panels and also new fuzzy window wipe strips. The stainless pieces run the entire length of the upper edge of the door panel. The fuzzies were approximately 24 inches long.
When I reinstalled the panel there was a gap of ~1/4" between the stainless strips and the bottom edge of the vent window frame. I could not figure out what is causing this gap and found no way to eliminate it. Last night I noticed that the fuzzy strip extends ~ 3 inches forward of the vertical (back) channel of the vent window frame. It looks like this section of fuzzy strip is hard agaist the extension of the vent frame that is the front channel of the side window. It seems to me that it is this section of fuzzy strip that is holding the door panel away from the vent frame. I'm ready to remove the door panel with the intention of cutting off that section of the fuzzy that extends forward of the vent window post, but I figure it's worth asking if others have encountered this before I go nuts with a hacksaw. Anyone?
Happy New Year
Happy New Year
