Just recently purchased 1968 convertible with the long term goal of being judged. In the interim it needs new tires. Any recommendations on the closest looking thing to the tires that came on it. Of course want radials
Tires for 1968
Tags: None
- Top
Re: Tires for 1968
Kenneth------
There is no radial tire that is configured anything like the original tires. Plus, you will find that finding any tire in the current P-metric size equivalent to the original tires (either 215-70-15 or 225-70-15) will be a challenge in itself. You will not be able to find a true high performance tire (i.e. "H", "Z", "W", or "Y" speed-rated) generally available in these sizes anymore.In Appreciation of John Hinckley- Top
Re: Tires for 1968
Hi Kenneth,
I purchased my '68 bias ply tires from Kelsey Tire http://www.kelseytire.com/home.html Bias ply is what came on your car and judges the best of all the reproduction tires on the market today. However, they are bias ply tires and are not the best for a comfortable ride as compared to today's radial tires. You will have to make the choice of which way to go. I drove my '68 with the bias ply tires to the Novi National last year and there was no problem, after the flat spots drove out. I lost 10% (3 points total) for configuration of the tires at the national. I should have asked more about this at the time but didn't. I'm not sure if or how the configuation differs from the original in the judges eye.
TerryTerry Buchanan
Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
Corvettes Owned:
1977 Coupe
1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
2003 Electron Blue Coupe
2019 Torch Red Grand Sport Coupe- Top
Re: Tires for 1968
I do not have the tank sticker - but the car came with hub caps - I really prefer the red line sidewalls.- Top
Re: Tires for 1968
Kenneth
If you want radials with red lines your going to be very limited. BF Goodrich has a tire: http://www.cokertire.com/p215-70r15-...ne-radial.html or you could go with Diamond Back: http://www.dbtires.com/. I can't think of any other tires off hand that match your criteria. Neither will be true performance tire.
I have Diamond Back tires on all three of my Corvettes (67, 68, 69) and I've been very pleased with them.
John- Top
