Any technique that will remove paint and leave the textured finish on plastic interior parts ? C3, Years ago I painted the parts with spray can Krylon paint
paint removal
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
Re: paint removal
Walnut shells or corncob media (think rifle reloading) via low pressure blaster.
I know one occasional (but well known) poster here who did this to remove black paint from interior parts and found a beautiful colored interior underneath.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Re: paint removal
You can try a towel with lacquer thinner on it, but doing a small section at a time. When the existing color is removed it would be a good idea to nuetralize it with simple green and water, a 50/50 combo. This method has worked for me in the past."SOLID LIFTERS MATTER"- Top
Re: paint removal
Try http://www.citristrip.com/
I used it and it didi not damage the plastic underneath. You can get it at Walmart
Try in an out of sight area first to insure it does not damage the plastic
Good luck, scott- Top
Re: paint removal
I would remove parts from the interior & go with a low pressur blaster. Find some one that understands what you are trying to do as not to alter the original finish.
GOOD LUCK KEN65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
