I removed starter motor 66 BB for wire harness repair and noticed numbers on block that starter covered up #s are 2769 with a side ways C ??
numbers starter area on 66 bb
Re: numbers starter area on 66 bb
Carl:
These numbers are most likely the engine block casting date. It is in the format of MONTH, DAY OF MONTH, AND YEAR. The month is a letter with A=January, the day of the month can be one or two digits, and the year is a single digit. Example: J76 is October 7, 1966, and B126 is February 12, 1966 These letters and numbers are generally "upside down" when viewed from below the car.....so approach it in this manner. Sometimes a mirror can help.
Look carefully and closely, as some of the letters and digits can appear different than they actually are (due to various casting flaws/issues, etc). What is the date that is on the engine pad which shows when the engine was assembled?? This may help to narrow down the engine casting date range.
Larry- Top
By chance are we talking about STAMPED numbers, and not cast; located on the flat machined (unpainted) bottom surface level with the oil pan flange ? (like pic below, only different #s)
Carl -- if I remember past posts, they had something to do with the piston sizing, as there's a number stamped opposite each piston opening, on the oilpan rail. Definitely a factory stamp. the other backwards "C" and the "+" might be rebuilders markings.
Re attached pic: So are you saying your numbers are stamped somewhere in this area, hidden by the starter when bolted in place ? the previous pic with the "10" is in the shadow, at the right margin on this shot.Attached Files- Top
