My '67 is on jacks. I removed all of the brackets, driveshaft and the shifter, but can't get the M20 out. I have a jack with a piece of wood supporting the engine under the oil pan, but the engine doesn't drop far enough. I have rotated the transmission, but am about 1/4" shy of clearing the bell housing. Do I need to drop the bell housing or remove the motormount bolts to drop the engine a bit more?
Question 2 - When I put the new transmission back in, will I need to adjust the shift rods or will the still be in correct adjustment?
