Re: Painting My '65
PPG DPLF Epoxy primer is a great two-part primer which comes in 6 colors,I use one that
is a closest macth to the topcoat color. Get a data sheet at the store or you can go PPG website and
get all their data info on everything they sell... the epoxy primer will fill but may need more coats
then the urethanes... I know PPG does not recommend any of their urethane primers that will have
a lacquer finish... you can use the old school acrylic primer surfacers[do not apply as the base coat on the entire car] for small things over the epoxy
base coat, also the Evercoat polyester glaze ( 2 part) works great for minor repairs and scratches too.
Remember, epoxy has great corrosion characteristics and would be the best for the frame too.
