Re: Lt1 fuel rail
Jim, at first blush I would say that there maybe a typo in the Judging Manual.
The Manual gives two numbers for the 1995 LT1 One being 10480200 , which is almost identical to the alternator you examined with a number of 10480202.
I did a survey on the radiator hoses and I did come up with a MUS for the lower radiator hose and a MVZ for the upper radiator hoses.
These can be verified by looking at the build sheet in blocks 45 for the MVZ and in block 46 you will find a 52. This is the last two numbers of the hose number of 10257252.
The early 95's had an upper hose number of 10262508.
This early number was not in the Judging Manual. I have sent the radiator hose survey to Tom Barr.
If you look under the hoses you can see a date code. The code is 063094 for June 30, 1994, for the upper hose.
