I am so close to finishing a 5 year restoration of my 1972 steel cities gray coupe and just re-installed the windshield after cleaning, stripping the windshield frame, spraying with etching primer, and then POR15 the whole thing. Luckily I didn't have rust issues at all and won't have to worry anymore about that crap! Anyhow... on the rear of the t top halo, the stamped stainless T piece under the t-tops, there is a groove between it and the rear fiberglass part of the roof and there was a greyish putty like sealer there when I removed it. What are you guys using to replace it and where are you getting it. I can not find much info other than using 3M black strip caulking.
thanks in advance,
Sully
thanks in advance,
Sully
