An authentic build sheet indicates a '66 was built with a particular original engine (427/435). The original engine is long since gone. We can verify what engine it shipped with and can obtain an original block with correct casting and build numbers and rebuild to OEM specs. Is it ethical to deck the block and restamp it w/ the '66 VIN and correct engine suffix? The engine build date will be a guesstimate and the broaching will be good but obviously not original. What disclosures are required or recommended? Is this a good or bad idea?
Ethics Question
Re: Ethics Question
1st thing IMO no way don't do it, 2nd thing IMO I agree with Mike I never heard of a 66 with that engine option didn't know it was available!!- Top
Re: Ethics Question
Mike, My fat fingers and lack of proofreading skills apologize. This is an L72 427/425. Al, I hear you about what may happen in the future. I can leave the pad blank as it is now but that still affords a future owner opportunity for mischief. If I want to restore back to original as much as possible, I have few options. There's no way to brand the title and any paper I may create can get separated from the car. Do I have to intentionally avoid building a correct engine due to potential future fraud?- Top
- Top
Re: Ethics Question
From the NCRS judging guides, it appears that representing a car as something it never was (i.e, stamped BBC in an original small car) is counterfeiting but replacing an engine case with an equivalent case is not. So, the NCRS standard seems to be a much lower standard than would apply in the general sales market.- Top
Re: Ethics Question
I once bought a car just like that, but the seller didn't disclose that it wasn't the original engine, it had a beautiful VIN and engine code stamp and the casting and date codes all fit the car's build date, and perfect broach marks and was listed and represented by the dealer as "numbers match". It even passed some NCRS judging. I had the original build sheet verified, it was legit, but, when I tracked down all the owners and found out it couldn't be the original engine, I felt I had been lied to and cheated. Full disclosure on all these things is necessary IMO. But after you sell it full disclosure, then what happens? Real problems IMO, I wouldn't do it.Big Tanks In the High Mountains of New Mexico- Top
Re: Ethics Question
I once bought a car just like that, but the seller didn't disclose that it wasn't the original engine, it had a beautiful VIN and engine code stamp and the casting and date codes all fit the car's build date, and perfect broach marks and was listed and represented by the dealer as "numbers match". It even passed some NCRS judging. I had the original build sheet verified, it was legit, but, when I tracked down all the owners and found out it couldn't be the original engine, I felt I had been lied to and cheated. Full disclosure on all these things is necessary IMO. But after you sell it full disclosure, then what happens? Real problems IMO, I wouldn't do it.- Top
Re: Ethics Question
So, to play devil's advocate for a moment, if the objective of NCRS judging is to evaluate the car "as it left the factory," why is such a restamp not grounds for automatic disqualification and only a points deduction if, for example, the broaching is incorrect?Big Tanks In the High Mountains of New Mexico- Top
Re: Ethics Question
On the other hand, there is a process whereby an option that was not fitted to the car at original build will take a complete deduct during judging and remain that way at future meets until such time as the non-original option is removed. If a base engine car somehow grew a high HP big block, each and every feature of the RPO would take a complete deduct, most likely rendering it to 2nd or 3rd Flight.
Sounds fair to me.- Top
Re: Ethics Question
An authentic build sheet indicates a '66 was built with a particular original engine..... The original engine is long since gone. We can verify what engine it shipped with and can obtain an original block with correct casting and build numbers and rebuild to OEM specs. Is it ethical to deck the block and restamp it w/ the '66 VIN and correct engine suffix? The engine build date will be a guesstimate and the broaching will be good but obviously not original. What disclosures are required or recommended? Is this a good or bad idea?
You can disclose that you have a restoration engine on the green sheets prior to judging. This will not affect the score unless it doesn't appear to be a typical pad.
tc- Top
Re: Ethics Question
Kind of curious what the point would be... do you have a goal of building a Top Flight car and this is the one thing that will make or break that goal?
Its obvious that you are not out to be a counterfeiter, as you probably wouldn't have posted your question here.
I think you should do what will help you sleep better at night. You will always know in your heart what the real deal is... There is not a lot of difference to me in telling people that, "I had the pad re-stamped to match the car", and "Its a replacement engine".
Tough choices... but I think I'd just leave it blank.- Top
Re: Ethics Question
Have you have your build sheet authenicated by the NCRS document group? If not, that should be the first action in the decision process. If it does prove to be real, go ahead and restore the car with the correct engine. Don't be surprized if the pad gets busted for the broach marks though. I'll bet big blocks get an extra dose of scrutiny on the field.
tcBig Tanks In the High Mountains of New Mexico- Top
