I would like to be able to touch up my transmission paint . Would their be a particular gray that was used ? My car is a driver so a close match would be good. Maybe a brush epoxy application ? Thanks
transmission paint
Re: transmission paint
Hi Wayne, probably the best paint is Krylon Dull Aluminum or whatever the vendors carry now in that type paint. (although not painted originally).1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
I'm with Gene, I've done dozens (hundreds) of transmissions over the last 40 years and none of the aluminum case versions were painted from the factory. The tailhousings were generally a different shade due to being die-cast rather than sand-cast, but neither was painted. I'd suggest a good aluminum cleaner.Bill Clupper #618- Top
- Top
