The old blower motor and fan is still on the car so i have to ask about the blower motor and fan for a factory AC 1964 coupe
I suppose there is no difference on the blower motor and fan for AC and no AC cars?
When i tried to assemble the fan to the AC blower motor there is a set screw on the shaft on the blower motor
Am i supposed to fasten the fan using the set screw? If i just use the nut that sit on the shaft on the blower motor the fan is loose(i can move it up and down)
Am i supposed to place the fan inside the blower motor fan case so the fan sits correct, then tighten the set screw on the shaft for so to tighten the nut that holds the fan to the blower motor?
If it is so i am a little worried that the set screw will come loose over time
Or is something supposed to sit between the blower motor and fan so the nut at the end of the shaft secures everything?
Have a look at the pictures to see what i mean
Shaft with the nut on the new blower motor for fasten the fan.jpgClose up of set screw on the shaft for the fan on the blower motor.jpg
I was thinking that it might be a spacer on the shaft from the blower motor and the fan?
by a previous owner; one close-up shot of
