Can anyone please tell me if there is a template available for drilling the holes to install the numbers on a hood. I can't bring myself to drill a hole until I know more.Thanks,Bruce
Template for installing 454 numbers on the 71 hood?
Re: Template for installing 454 numbers on the 71 hood?
Bruce, The AIM does have the measurements for drilling the holes, But the easier way is if someone has a hood with the numbers off and made a template. I don't know about you but hate to think about drilling holes and making one mistake. Maybe someone has does this on the TDB and made a template or can make one, If I had a big block I Would make one for you.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Thanks Monte, that would be a great help. Would you like fax#, email or US Mail? I would be glad to have it whenever you get a chance to do it.- Top
Beware. My 427 numbers on one side of my factory hood were all crooked. Just because the factory did it doesn't mean it was correct.- Top
I'd avoid fax and printing. The scaling won't be exact. Shoot for either a dimensioned drawing or a template made diectly from the hood and mailed to you.
Tom1958, 283/245, White/red - Top Flight, October 2016
2007 Z06, Lemans Blue
Newsletter Editor, Delaware Valley Chapter- Top
454 Hood Template.jpg IMG_0090.jpgBruce,
Don't worry. The way I am sending it to you is almost fool proof. Send me your private email and I will send you over the pictures of the lay-out of the template. I am sure you will see how easy it will be for you to get this right.
If I were drillingmy hoodnow, I would lower the first "4" 1/8" to 3/16" to make them line up better. But, this is how it was done at the factory.
Once you lay it on there it will not be able to move.
Best of luck.Attached Files- Top
Monte,
Thanks again for helping me out. My email: batmat@visuallink.com
Bruce- Top
Bruce,
I zoomed in and out on the picture with the holes on it. Once I got the blue tape to be 1 1/2" wide by zooming in and out, I laid a piece of white paper over the screen.
I then copied the holes on the piece of paper. Then took the piece of paper outside to the car and the template fit exacly as if I took it off the car itself.
just an idea, but it worked, it worked very well.
Once again, best of luck,
and happy to have helped.
I hope this helped others as well.
Monte- Top
