Hello. I have done a thorough search on the forum about this and thought I'd post my situation for further insight. Our '66 coupe is just out of a 10-month restoration. Before the car came apart, all lights and signals worked fine.
Now as I am reassembling and getting it ready for the road, there are some perplexing issues with the directional signals and brake lights. Specifically, here is what works and what does not:
Works: head and tail lights, back up lights, parking lights, right hand turn signals
Does not work: brake lights, turn signals on left side (front and back)
Odd stuff: When stepping on the brake, the right turn signals will blink and continue to blink regardless of where the turn signal lever is positioned. I can cancel the blinking by moving the lever.
I have replaced the flasher unit, have checked the switch affixed to the steering column, and have looked at, but have not replaced any fuses. I assume I have a good ground based on the fact that headlights and parking lights all work front and back.
I sure would appreciate any advice you might be able to offer. Thanks and best wishes.
