What is the best way to strip a original 1957 steering wheel?
C1 steering wheel
Re: C1 sterring wheel
I have removed paint from plastic dash parts using Pinesol full strength. You will need to submerged the steering wheel. It removes the paint and has not damaged any of the plastic parts that I have worked on. I believe it was something I found out about on the internet somewhere. Main thing it does not damage anything.
Phil- Top
I have used Pinesol as Phil did on plastic (styrene) and metal. Works great without damaging. Has anyone tried Pinesol on vinyl to remove interior dye???I have removed paint from plastic dash parts using Pinesol full strength. You will need to submerged the steering wheel. It removes the paint and has not damaged any of the plastic parts that I have worked on. I believe it was something I found out about on the internet somewhere. Main thing it does not damage anything.
Phil- Top
