What prompted me to rebuild my 59' WCFB was from doing too much sitting in the garage I would go to start it and it would start fine and then die after it used up the fuel in the primary bowl. Iwould tap on the carb or take the top off and reinstall and things would be fine for awhile. I figured the primary flout was sticking and time for a complete cleaning and rebuild. Well thanks to manuals provided by Phil I complted the rebuild.I replaced everything in the kit except the ball bearing and retainer beneath the accelerater pump. Well When I first start it it's smooth and happy , once I believe the secondary well fills up you can visibly see fuel being sucked out of the secondary jets and the engine floods. I took the top end off to check the floats and if anything they seemed stuck close. It seemed to matter which side of the float assy. that I
placed the needle connecting clip. So in closing, does any body have an idea why my wcfb is pumping fuel out of the secondary when it is not wanted or needed.
