461 heads with no end markings - NCRS Discussion Boards
  • Patrick S.
    • January 1, 1988
    • 209
    Has anyone else got or seen 3782461 cylinder heads without the "double hump" cast into the end?
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 461 heads with no end markings
    none in my collection.mike
    • Patrick S.
      • January 1, 1988
      • 209
      I have 2, one in my 62 FI dated December 1961 and another dated January 1965. The one on the engine was "caught" at the Nationals (I never noticed it). Just curious.
      • Jim L.
        • September 30, 1979
        • 1805
        I've heard of such things...... usually from someone who was trying to build a "cheater" racing engine.
        • John D.
          • December 1, 1979
          • 5507
          Patrick and others. Doen't the early 62 461 have a camel hump that has the top of it cut off some? John
          • Mike M.
            • May 31, 1974
            • 8365
            the 61 camel humps were squared-off as well. mike
            • Dennis C.
              • June 30, 2002
              • 884
              John,
              i recently judged a 62 with one of the humps at each end shorter then the other. Everything else looked correct.
              Dennis
              • Jim L.
                • 1805
                Here is a shot of a '61 head cast in late '60. The squared tops of the humps are clearly visible:
                • Jerry G.
                  • April 1, 1985
                  • 1022
                  Agreed. Warshosky makes all sorts of cheater heads. I had them port a set of real 461 heads and they screwed them up. Don't use them. Jerry
                  • William C.
                    • May 31, 1975
                    • 6037
                    My early '62 heads (cast in '61) are the same.
                    Bill Clupper #618
                    • Tom P.
                      • April 1, 1980
                      • 1814
                      I have a pair (461X) that have a "notch" cut out of just one hump on each end. These are on the fresh 383 in my 51 Chevy.
                      And speaking of "cheater" heads, this is a 66 462 2.02 set of heads on the SB400 in my 56.
                      Humps ground off and a pyramid symbol shaped to resemble a 57 539 head. Back in the day of running in a pure stock class (such as in a 57 Chevy), this was done by a few guys "in the know" so that heads with bigger valves could be installed for added performance. I bought these from a friend 25-30yrs ago.
                      • Mike M.
                        • May 31, 1974
                        • 8365
                        Tom: after removing the camel's humps, take a needle air hammer(like the navy uses to de-rust their ships) and beat the hell out of the casting area where the humps have gone bye-bye. the air hammer will give the surface a rough, sand cast finish. i assume JB Weld or a similar epoxy was used to create the triangle on the top of the rectangle.one can also remove the 6 motor mount bosses on the side of the block to simulate a 348 block. the boos to attach the Z-bar pivot will also need to leave. all of the above is second hand info. regards,mike
                        • Tom P.
                          • April 1, 1980
                          • 1814
                          Mike,
                          Where the two humps used to be, that area was ground down low enough so that the pyramid symbol could be formed in the remaining flat symbol. Thus, it is ALL metal. "Back in the day" the tech inspectors at the strip didn't notice the height of the flat portion. they were only looking for the actual symbol. And since the 539 heads were used on 57 FI engines as well as "Power Pack" engines in the pass cars, they didn't catch on--------------------------------at first. As time went by, and tech inspectors became better educated/knowledgeable, they took a closer look at the ends of the heads.
                          My heads above had undergone some SERIOUS abuse back in their day, but when I had them rebuilt, my machinist said they were near perfect. I no longer have to worry about tech inspectors, so I've had them lightly messaged internally, plus additional bosses welded, drilled, tapped so that staggered 9-fin covers can be used.
                          • Vinnie P.
                            Editor NCRS Restorer Magazine
                            • May 31, 1990
                            • 1557
                            Hearsay only...never any first-hand knowledge!!!!!
                            • Tom L.
                              • October 17, 2006
                              • 1439
                              A while back when I was into the racing game I "heard" of a company that might just do this king of thing. Here's the link:
                              “Masters of Disguise” to Iron Eagle Small Block Chevy and other racing cylinder heads Iron Eagle Platinum castings, 200cc straight plug with our ’492 disguise package.[/one_half]   Cylinder Head Design Form: Fill out our online form for a recommendation and … Continue reading →
                              But seriously, not sure why I know about this
