Keys for judging?
Re: Keys for judging?
Mike,
You should have a total of four keys (not counting a possible B&S alarm key, which I can't recall existed for which years), all with functional key cuts. Among those four GM keys, you should have two identical "large-head" square keys, and two identical "large-head" oval keys. The letter keyways for the 70-72 years are:
70: J & K
71: A & B
72: C & D
Gary- Top
One small correction, very minor. It is my understanding that the keys that are correct for the car and are judged with the interior do not have to work anything. The operation of the locks is handled during operations and any keys can be used. If this is wrong I would appreciate someone stepping in.
Jeff- Top
Jeff,
You are correct that the keys are only to be judged for quantity and appearance, per 1970-72 TIMJG page 28.
My interpretation of the TIMJG was that it was vague on whether the second set of keys needed to be cut or not. (Looks like they do.)- Top
Jeff,
I checked the '66 TIM&JG and you are correct that the function of the keys in the various locks is assessed during OPs. The originality and condition of the keys, at least for '66, is judged with the Interior assessment, during the ignition switch portion of the Controls section. I presume during that originality assessment, a judge would detect and deduct for the lack of cuts on any key. But you are correct that the function of any key is not assessed during the Interior judging.
I suppose during the OPs check, a judge might check the function of all four keys, which again would catch any uncut keys. So it seems like the issue of having any uncut keys could arise both during OPs (for function) and during the Interior judging (for originality).
Gary- Top
The key people are Gary Beaupre and Peter Lindahl. The size stamp is not so common. I know Pete can stamp them correctly. You will have to ask Gary if he can.
The key notches are sheared with a cutting tool, and not ground with a wheel. Yes the judges can discern the difference. Do it once and do it right.
Edit add: There is a difference in whether the key has a small hole or a large hole, and I think it depends on the year of your car. Check with the key people, the story they wrote for The Restorer, or the appropriate TIM&JG.Terry- Top
Terry,
For the large head keys that came into existence in '69, there is only one size hole (small) in the knockouts.
Gary- Top
Terry- Top
Terry,
One can count on the fingers of one hand the number of people around the country who do a decent or better job at stamping keys intended for NCRS judging. Each person has his own unique, stamping fingerprint. While some locksmiths say they can stamp keys, they typically have not researched the correct font style and size. As you aptly state, do it once and do it right.
Pete is my personal choice for stamping keys intended for judging. His prices are fair and without question he stands behind his work.
Gary- Top
