I am going to buy reproduction exhaust tips for my 71 LS5, I am assuming I need the 2.5 inch exhaust system, however, I am reading that the exhaust tips are 2 inches. Can someone explain to me how the car was originally done. In other words how do I get the correct exhaust tips on my car if it has the 2.5 inch pipes. Thanks in advance.
71 Exhaust Tips on 2.5 inch exhaust?
Re: 71 Exhaust Tips on 2.5 inch exhaust?
Frank------I am going to buy reproduction exhaust tips for my 71 LS5, I am assuming I need the 2.5 inch exhaust system, however, I am reading that the exhaust tips are 2 inches. Can someone explain to me how the car was originally done. In other words how do I get the correct exhaust tips on my car if it has the 2.5 inch pipes. Thanks in advance.
Your 1971 LS-5 does use a 2-1/2" exhaust system. This includes the front and rear exhaust pipes. However, it does NOT include the muffler outlet pipes to which the exhaust extensions ("tips") attach. All 1963-73 Corvette muffler outlet pipes are 2" regardless of the size the exhaust system pipes.In Appreciation of John Hinckley- Top
It may seem silly Frank, but from an engineering standpoint it makes some sense. The exhaust gasses cool as they travel through the pipes and muffler and as a result of that cooling they take up less volume. I have never measured the muffler's internals, but I suspect they may only be 2-inches anyway.Terry- Top
Reba has the '68 off road mufflers on the Frog. Sounds very good, mellow, not loud. Were purchased when they were still available from the GeneralDick Whittington- Top
hey ---
if you want to get the best reproduction exhaust tips for your car, purchase a set from Richard Fortier. He advertises in the Drive Line. he is the only guy out there that makes a set damn near exact to the original assembly line tips. They are not stainless - but carbon steel chromed and welded as originals were. Well worth the extra dollars IMHO...
Bill- Top
