Some of you guys that have lead hammers for knock off wheels what size hammer should I use( how many lbs.)?, another thing does any one use a dead blow hammer with the plastic head? seems to be quite a few different sizes on both types. Thanks Ed
Lead hammer question
Re: Lead hammer question
Ed -
Most of the Cobra guys use the "Mother-Thumper" (Google it for sources) 5# or 6# hammer; a similar one is made by the Imperial Hammer Co. in Rockord, Illinois. DO NOT use a plastic dead-blow hammer, except to "snug them up" - tightening them properly requires a good LEAD hammer.- Top
Here's the 5 lb ***** Thumper, alongside a GM original service.
I see the software still does not allow us to use the real name of the item "m_u_t_h_a" Thumper
Attached Files- Top
I just ordered my mother Thumper and they also they sell a special anti seize compound.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Speaking of anti-seize and KO wheels, my spinners have pretty rusted threads - is it safe to put anti-seize on the threads when re-installing? - thanks, sl- Top
Steve I use anti seize on my knock off threads, only a very same amount. I would clean the rust off the threads first. That could cause a problem if the spinners are not torqued correctly.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
The 6# version of the American Hammer is also a good choice. They will recast the head when needed.Ed -
Brass Hammers Bronze Hammers Copper Hammers CRYO HAMMERS DEAD BLOW HAMMERS FME HAMMERS LEAD HAMMERS Zinc Hammers American Hammer manufactures quality industrial hammers favored by professional machinists who need to get the job done right. An industry leader for more than twenty-five years,
Lead HAMMERS Our lead alloy hammers are our most versatile striking tool. All applications considered are for the purpose of moving material without damaging the striking surface. From straightening drive shafts to assembling gear boxes, no man-made material can replace the dead blow characteristics of our lead hammers. If you would like to join- Top
