This forum is a huge help and source of encouragement. I have the frame off and have started cleaning the underside. I pulled the splash shields of and on the drivers side in yellow the letters PB are written. Obviously a reference to power brakes. On the passengers side it says 588 x. Any ideas what that means? Also not related, I found a contact switch, not attached to anything hanging by the wires by the washer motor. Again any idea what its for?
yellow markings under splash shields on my 75 roadster
Re: yellow markings under splash shields on my 75 roadster
That is the body's job number assignment in the body shop to coordinate panels as they were built for your vehicle. If you have the buildsheet, it should reconcile with Box 10 SCHED NO data. Here's a link to an excerpt from the buildsheet book that introduces the topic.This forum is a huge help and source of encouragement. I have the frame off and have started cleaning the underside. I pulled the splash shields of and on the drivers side in yellow the letters PB are written. Obviously a reference to power brakes. On the passengers side it says 588 x. Any ideas what that means?
If you can take and post a picture, we could figure it out but the only switch in the engine compartment should be the alarm switch but it shouldn't be hanging around.Also not related, I found a contact switch, not attached to anything hanging by the wires by the washer motor. Again any idea what its for?Tom Russo
78 SA NCRS 5 Star Bowtie78 Pace Car L82 M2100 MY/TR/Conv- Top
Thanks Tony,
The alarm switch for the hood I see. It looks like a door light switch. This is different, the switch looks more like a headlight door switch. I will take a pic and post it.- Top
Figured it out! That switch mounts behind the anti theft key switch. I guess if someone tries to pry the key switch out of the car, this switch will sense that and set off the alarm.- Top
