Which terminal do you have your number 1 spark plug wire at?
Re: Which terminal do you have your number 1 spark plug wire at?
Here's a pic of my 68 L36 set to 4 BTDC. After looking at the AIM I think it may be off one tooth, want do you think?
DougIMG_2089.JPG- Top
You might try clocking it 1 tooth clockwise. That way the VAC port will be to the rear of the plug wire bracket, and the dist. cap screws oriented like AIM.
Plus your current orientation will be even more counter-clockwise if you decide to advance the timing a bit.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
I think you're right, should put the can in the center of the open space. I'll have to put that on my to low priority to do list.
Thanks, Doug- Top
The dist. gear has 13 teeth, so moving it 1 tooth will turn the distributor 28 degrees. This means the #1 tower will move to a little more than midway between where #8 and #4 are located now.Mark Edmondson
Dallas, Texas
Texas Chapter
Sounds about perfect. Thought about leaving the rotor where it is, rotating the body 45 degrees CW and moving each wire one spot CCW but I think thats moves it a bit too far and would put the can too close to the rear wall of the shielding, too bad as it'd be much easier. Looks like I'm gonna have to at least partially pull the distributor.
Doug- Top
Doug,
You'll need to completely remove the distributor so you can turn the oil pump shaft.Mark Edmondson
Dallas, Texas
Texas Chapter
