small holes in inner fender well - NCRS Discussion Boards
  • Ruedi K.
    • December 12, 2011
    • 242
    Re: clip picture and passenger side harness routing
    So, it seems that the brackets where the horns should attach are missing on this radiator support? I read something about the 63 radiator supports being unique. By the way, I couldn't find any other evidence of holes for a Fuelie air filter, so it seems somebody had just fun drilling a few additional holes in a line.
    Here are pictures of the radiator support currently in my car.
    Thank you
    • Monte M.
      • January 1, 1991
      • 687
      Ruedi,
      It looks like a 64 support from what I can see. What is the vin number if your car? If you are interested I have a variety of 63 Blocks here.
      My e-mail is mbusiness@comcast.net. That was you can send me things direct and I can let you know what I have.
      Best of luck with the car.
      Monte
      • Ruedi K.
        • December 12, 2011
        • 242
        #18
        Hello Monte
        Attached is a picture of the plate with the serial number. As we cannot have our cars judged here in Switzerland, I will leave that block in. It is not even sure if the original block was replaced under warranty and the local dealer in Switzerland just stamped the new block "his way" (was an export car to Switzerland). And I live in Switzerland. But the things I replace in the car from now on, will look as they should.
        But thank you for the offer with the engine. For now, I will exchange that 64 radiator support with a 63 style, so I do not have that hole any longer. Changed my mind, removal is too dangerous, will just close the hole with a plate. Thanks for all advice.
        Regards
        Ruedi
