On my latest Sunday Morning ride with my 63 L-76 (after a 2 month layup), I noticed a hic-up in the cranking during my last re-start to drive it into the garage. I put my Battery Minder on the battery and within a few short hours the battery was completely dead (down to 5.5 volts). The battery is a "Restoration Battery" (AGM) and is about 4 to 5 years old (looking for paper work as my son bought it for me).
My first attempt to recharge it with my new charger got a "bat bad" shut down. Then I completely isolated the battery from the cables and the charger pulled it up to 13.9 volts in 2 hours. I re-connected the Battery Minder (and cables) thinking it would then trickle it back up to full charge. But again, within a few hours, the battery was completely dead. As it took a charge once already, I let it charge for another 2 hours and it reached 14.2 volts. So, this time I left it disconnected from the cables (and trickle charger) and let it sit overnight. The next day it checked in at a full 12 volts with my multimeter. I again let it sit for another night and it again checked in as fully charged.
As a caveat to this problem; several months ago I had trouble with the connector on the alternator that has the 2 small wires with faston female connectors within a plastic plug. The plug had rotted away after only 50 years and one of the wires was not making contact. I noticed this condition on my dash ammeter while driving. I did a temporary fix with tape, then found a replacement "pig tail" at my NAPA store. However, as my wires and fastons looked good I just used the new plastic plug with my wires (not wanting to do a splice). The plastic plug fit very tight in the alternator, and when I would wiggle it around I would hear a contact in my voltage regulator make and break. So, I cut down the plug so that it would fit more fully in. I did this during my charging efforts, but it made no difference,
Also, I have not had any signs of any starter trouble to date. Both my cables are fairly new, and my alternator was restored with new diodes installed about 5,000 miles ago. My voltage regulator was also replaced then.
I spoke with Tom at Restoration Battery last week and he had me do some additional tests and, at that time, we concluded the battery was gone. But, now I no longer believe that. He confirmed that my Battery Minder was a rather old model and not the preferred unit to use with this battery, but he didn't consider that it would be harmful. I have some male faston rings on my battery posts to which I connect the trickle charger to and have a small LED battery condition checking meter connected there as well. I also use the "knife switch" type ground disconnect. All of these were disconnected during the last 2 charging attempts.
Any ideas that would shorten my trouble shooting time???
Stu Fox
Stu Fox
