Battery Charging Problem - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1580
    Re: Battery Charging Problem
    Originally posted by Donald Olson (17357)
    Stu,
    If you are concerned about the health of your battery, take it to a FLAPS that will do a free draw down test. The test IIRC is only about 5 minutes
    DonO
    Originally posted by Paul Jordan (49474)
    Volts are only part it. Even a bad battery can show 12+ volts. You need amps to start a car.
    Which is why I suggested a battery draw down test.
