Thanks. I think I get it now. *NM*
C2 distributor
Re: Help for the helpless
Swap meets are a great source for used single-point Delco tach-drive distributors; a couple of hours of bench work to rebuild one, get it on a Sun machine to re-curve it to the specs you want, and you're in business.
Attached Files- Top
Attached Files- Top
Re: Thanks. I think I get it now.
Steve-----
Believe me, you're not going to get a GM #1111069 distributor from Jegs, Summit, GM Parts Direct or any other GM dealer. This particular distributor was GM-discontinued more than 25 years ago. As others have said, you can "create" a distributor with identical advance characteristics from just about any Corvette distributor.In Appreciation of John Hinckley- Top
Steve-----
Ran across this is Hemmings. They have a 111069.
http://www.hemmings.com/index.cfm/fu...tail/id/546661- Top
