Restoration Documents Main Page
Please note that some links to ncrsmac.org may be broken. See Post#87 for corrected links.
Updated 05/6/2025
Updated 05/6/2025
I will update this initial post with new files as I receive them. If you have a file you'd like to add, feel free to create a new post and when time permits I will add it to the "Update Page" for ease of access, or contact me by Member email if you want to send me files or photos. Member PMs or Emails do not allow attachments unless from a URL.
Eventually these updated files will be added to the main page list.
Edits to this post that I make will not send you a email notification so keep an eye on this thread for updates even though you may be subscribed to it. This Thread is a continued work in progress. Many thanks to all that have helped to improve this feature.
Latest Updates in "Update Page" (or this Main Page for new revisions of older docs) are below.
Most recent at top of list.
Edit: 05/6/2025 - Corrected (ncrsmac.org) links for the John Hinckley Assembly Processes Part 2 and Part 3. SEE Post#87 HERE for a complete link of ncrsmac links.
Edit: 10/16/2024 - Added Distributor Applications thread link.
Edit: 3/07/2024 - Added new link to pdf file to Update Page. John Hinckley Memoirs
Edit: 2/20/2024 - Added new file to Update Page. 1965/1966 Tele Steering Column Chevrolet Service Manual extract
Edit: 7/10/2023 - Added new link to Update Page.
Links to Mike Hunt 1956 & 1957 Surveys in Post#78
Edit: 7/10/2023 - Added new file to Update Page.
Water Pump Rebuild
Headlight Switch repair
Edit: 7/6/2023 - Added 2 new files to Update Page.
Carburetor - Carter AFB Data
Edit: 7/2/2023 - Added new file to Update Page.
Bolt Grade Chart - GM to SAE
Edit: 4/21/2023 - Added 3 new files to Update Page.
Torque and Anti Seize related
Edit: 3/27/2023 - Added 2 new files to Update Page.
C2 Instrument Cluster & Dash related
Edit: 1/14/2023 - Added new file to Update Page.
C1/C2 Oil Canister Rebuild
Edit: 11/29/2022 - Updated file on this Main Page. Heading "Engine Rebuild".
C2 300HP Engine tech paper Rev3 - Duke Williams (replaces 2019 Rev2 version)
Edit: 11/29/2022 - Added new file to Update Page.
C2/C3 1963-1982 Rear spring Data - Gary Beaupre & Joe Lucia
Edit: 3/4/2022 - Added new files to Update Page.
C3 Seat Cover - Patrick Boyd
C1 Wiper Motors Service News - 2 files - Gary Chesnut
Edit: 10/19/2021 - Added new file to Update Page.
C1 Front Park Brake Cable - Dave Zuberer
Edit: 10/08/2021 - Added new file to Update Page.
C2 Door Anatomy Update - Dave Zuberer
Edit: 09/07/2021 - Added 3 new files to Update Page.
Steering Column Rebuild 1964,1965,1966Steering Wheel Restoration 1956-1962Steering Column Rebuild 1964,1965,1966
Edit: 02/15/2021 - Added new file to Update Page. C2 Ground Straps & More Hardware Details
Edit: 02/13/2021 - Added 2 new files to Update Page.
C1 Horn Repair &
C2 1967 Telescopic Steering Column Rebuild
Special thanks to Dave Zuberer for PDF file creation from the web based HTMLs with enhancements.
Edit: 01/23/2021 - Added new file to Update Page. C2 Ground Straps & Hardware
Edit: 12/21/2020 - Added new file to Update Page. C2 Ground Straps & Hardware(archived)
Edit: 12/19/2020 - Added new file to Update Page. C2 Headlight Motor Diagnosis & Repair
Edit: 11/29/2020 - Added new file to Update Page. C6 Automatic Shifter Issues
Edit: 10/14/2020 - Added 2 new files to Update Page.
Bulkhead/Firewall Connector Repair &
Water Pump Rebuild - Reproduction Kits
Edit: 09/03/2020 - Added new file to Update Page. Windshield/Sideglass/Vent / C2
Edit: 09/03/2020 - Added Keywords / "C" gen
Edit: 8/20/2020 - Updated downloadable PDF list with all originally posted document files along with some additional files. This was originally composed by Mark Francis and attached to post#45. I have reorganized his post and moved the updated pdf to this first post for easier access.
Complete Database of Documents Information
Please see Attached Complete List PDF ( Restoration Documents ver 8-20-20.pdf ) It has the same file list as below and all file links are functional. Note when you download and open the file locally, you must remain logged in to the TDB to access and download the files to your computer/device for the files that reside on the NCRS site. Some files are linked to other sites.
Below is the list from the above pdf. I've included it here for instant access if you do not want to download the above Complete List pdf file for local access.
Original Post: July 4, 2017
There was discussion a while ago about constructing a place for historical restoration and informational documents. Until that happens this may be a start as a placeholder of information.
Attached is a compilation of documents I have collected over the years. Most of what this consists of are converted HTML files from our own TDB and other Public Forums. Special thanks to Dave Zuberer for PDF conversion and Professionalizing many of the HTML Forum threads, and so many others who have contributed to this information. When more becomes available I will add them in the UPDATE Page.
Also attached are JPG files I've either created or acquired from others.
The names of the files are self explanatory. A simple method to search this list is to use your Browser presently viewed page Search function, the "Ctrl F" keystroke. This will search the text within the post for the keyword(s) entered. Enter the keyword in the Search box after Ctrl F is typed and it should bring you to what you're looking for.
Rich
