Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
Warning: Trying to access array offset on value of type bool in .../vb/library/node.php on line 1951
Warning: Trying to access array offset on value of type bool in .../vb/library/node.php on line 1952
Adding Power Steering to a C2 Top Flight Car -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
FWIW if P48 is an original option there are signs of that. Their credibility will be greater if those parts remain the originals and were not replaced during restoration. So it is detectable particularly when there is communication between judging teams.
Respectfully I disagree that there should be an allowance made in judging for the incompetent. The car is being assessed not the owner or some occasional non owner driver.
Dan: If that is the case then there should be "Total Deductions" for Battery/Fan Belts/Tires/Filters and any serviceable part that
is on the car but is NOT> "THE" ORIGINAL THAT CAME WITH IT. No allowance made in judging as you stated. JMHO Thanks
Larry
i do have this book , still doesnt answer my question, if i bring my 1963 z06 with 2 bar knockoff to any NCRS judging meet i,am going to get deducted for wheels
Please don't hijack other's threads. Start your own.
L Larry: Replacement, reproduction, service parts and so on do receive deductions when they are sufficiently discernible from the appearance of original parts. Cars are judged on appearing as original. Not whether they are in ever aspect absolutely original i.e. parts,engines, paint etc. Simply if it looks like a duck it is viewed as a duck. A common fallacy is that a Flight Award certifies something is original. They do not. These awards indicate a car appeared as an original car would on a specified day.
I suggest you read the Judging Reference Manual. The Judging Retreat in Texas would be of benefit as well.
Larry
Those items you mention are subject to some type deduction as everyone of them has differences from originals. The amount of deduct would depend on the closeness to original configuration.
Yesterday old JD did a fuel injection seminar for the Pittsburgh Tri-State chapter. I was asked how many '57's had fuel injections. My answer was all of them.
Because Dan Lynch is adding power steering which is a factory option was it born with power steering who knows and wants to know if it's going costing him points , my question is I come in with my 63 Z06 with knock off wheels was it born with knock off who knows it's a factory option but i get deducted big time for wrong wheels why's that .
Because Dan Lynch is adding power steering which is a factory option was it born with power steering who knows and wants to know if it's going costing him points , my question is I come in with my 63 Z06 with knock off wheels was it born with knock off maybe it's a factory option but i get deducted for wrong wheels why's that .
Danny,
You are likely to get more responses to your question if you start a separate thread. Some folks will see power steering, think “Chassis” and put thread on ignore. Your wheel question is one dealing with “Exterior”. More likely to get exterior judges making comment.
