1967 electrical fuses
Re: 1967 electrical fuses
Didn't Littlefuse stripe them on the outside?Tim - I checked the LI Catalog I have, #22, and they are listed as FUSE SET (OEM WITH CORRECT COLOR STRIPES)(8 PC) for 63-67. While I find LI is usually correct on their applications, the first application of the color-coded fuses to Corvettes and other other GM vehicles was with the 1967 production year. Also, worth noting for my experience is that while the color stripes are were "correct" on the sets I have seen the stripe is on the outside of the glass tube while the original Buss color-coded glass tube fuses had the stripe on the inside of the glass tube. Pete- Top
Brian - All the examples of Littelfuse glass tube fuses that I've seen that were color coded had a "dot" or dab of the coding paint on the outside of the glass which is one of the accepted methods of color-coding. I have not seen any examples of Littelfuse fuses with a colored stripe around the glass tube, but that's not to say Littelfuse didn't use that method also; it's that I haven't seen examples of them. If you have examples, I'd be interested in seeing some. Pete- Top
Here is an example of a Littelfuse with the stripe and amperage painted on the outside for a 15amp fuse.Brian - All the examples of Littelfuse glass tube fuses that I've seen that were color coded had a "dot" or dab of the coding paint on the outside of the glass which is one of the accepted methods of color-coding. I have not seen any examples of Littelfuse fuses with a colored stripe around the glass tube, but that's not to say Littelfuse didn't use that method also; it's that I haven't seen examples of them. If you have examples, I'd be interested in seeing some. PeteAttached Files- Top
Robert -
Littelfuse obviously had a Manufacturing guy making the decision to paint-mark the fuses on the outside rather than on the inside; that eliminated the need to stage the glass tubes for AGC fuses ahead of cap-and-element assembly by colors for the various amp ratings; they could mark them after assembly, using one common glass tube for all ratings.
