Re: Edelbrock Electric Choke Issue
Hi guys,
Needed a winter fix, so I'm in NC skiing with the family. This is what happens when you live in South Florida
. Before we left, I noticed that my accelerator nozzles were not squirting on time, and the shot was very weak. My old pump worked perfectly, but I replaced it while the carb was open just to be proactive. Obviously, something is wrong with the pump or .043 nozzle. Even with the near nonexistent pump shot, the hesitation is not as bad as it was before. When I return next week, I will replace the nozzle for the .024 and see what's up with the pump. The original nozzle was a .033, so I think a good pump shot with the smaller nozzle might solve the problem. I will also try to adjust the throttle plates to the recommended .020 transfer slot exposure so the passenger side A/F emulsion screw works properly. Stay tuned...
Hitting the slopes,
Roger (50141)
Hi guys,
. Before we left, I noticed that my accelerator nozzles were not squirting on time, and the shot was very weak. My old pump worked perfectly, but I replaced it while the carb was open just to be proactive. Obviously, something is wrong with the pump or .043 nozzle. Even with the near nonexistent pump shot, the hesitation is not as bad as it was before. When I return next week, I will replace the nozzle for the .024 and see what's up with the pump. The original nozzle was a .033, so I think a good pump shot with the smaller nozzle might solve the problem. I will also try to adjust the throttle plates to the recommended .020 transfer slot exposure so the passenger side A/F emulsion screw works properly. Stay tuned...Hitting the slopes,
Roger (50141)
, but I know what to do when I return home next week!
