67 - Stop & Rear Hazard lights not working - NCRS Discussion Boards
  • Ron N.
    • August 18, 2008
    • 243
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 67 - Stop & Rear Hazard lights not working
    Hazzard switch.
    • Ron N.
      • August 18, 2008
      • 243
      Wayne, is the Hazard switch located in the steering column? I can't find it in the assembly manual. How does it affect stop lights?
      Ron
      • Wayne W.
        • April 30, 1982
        • 3605
        Ron
        Yes, and when activated takes the turns out of the circuit.
        • Ray G.
          • May 31, 1986
          • 1187
          Hello;
          Brake light wiring routed through directional light switch.
          Try plugging in a donor directional light switch.
          Use a 12V test light to follow voltage.
          Good Luck.
          Ray
          I hope you dance
            Ron
            Ron -
            It's on the passenger side of the steering column bowl, directly opposite of the turn signal lever; has a little chrome knob threaded into it (the switch itself is inside the column, part of the turn signal switch).
            • Keith B.
              • December 1, 1991
              • 397
              long island just put them back out for sale. There has beena long wait for the switch. Better get one now before they go away again. It takes about an hour to fix.
              Keith Burmeister
              • Timothy B.
                • April 30, 1983
                • 5177
                Ron,
                Also check the fuse panel clips where the fuse plugs in to be sure there is a good contact showing voltage on each side of the fuse. Only takes a minute with a test light, that's where my problem was.
                • Ron N.
                  • August 18, 2008
                  • 243
                  I never would have thought that the hazard and stop lights were incorporated in the direction switch. Ordered a switch from LIC and will install when I get it.
                  Thanks to all for the help.
                  Ron
                  • Gerard F.
                    • June 30, 2004
                    • 3803
                    Ron,
                    Take a look at this thread:
                    https://www.forums.ncrs.org/showthre...=signal+switch
                    In the first post is a schematic of the 67 signal switch. If you trace the hazard and brake line feeds to the rear tail lights, you will see that they come together at the cam on the signal switch.
                    If you have front hazards, and no rear hazards or brake lights, the problem is in that little cam and the contacts between the cam and the body of the switch.
                    You are better off just replacing the switch, then playing around with replacing the cam.
                    When you get the new switch, make sure you check the area between the cam and main body. I had one replacement switch that had so much grease on the contacts that it only lasted about six months before it built up enough carbon to short it out. Make sure the contacts only have a light coating of diaelectric grease.
                    Jerry Fuccillo
                    • Gerard F.
                      • June 30, 2004
                      • 3803
                      Ron,
                      Also when you put the new signal switch on, take a look at my little trick with lever mounting screw in that archived post. Use a shorter screw with a lock washer so that there is a constant compression on the cam, and that the lever doesn't wobble fore and aft.
                      Jerry Fuccillo
                      • Keith B.
                        • December 1, 1991
                        • 397
                        Hopefully you ordered the switch. It is red now (orginal was white) you might want to put a touch of white paint on the side of the switch because it is noticable at the hazzard switch opening when you sit in the passenger seat. I agree you will need a shorter screw for the turn signal. You must loosen the steering column to allow the wires to be removed. look for the original sticker that surrounds the wires. It can be removed if you are careful (wait till you have it out of the car). The curved plastic connectors are not the same color as the originals. You can easily push the wires out and put them into the original plastic.
                        Keith Burmeister
                        • Donald O.
                          • May 31, 1990
                          • 1580
                          Originally posted by Gerard Fuccillo (42179)
                          Ron,
                          Using the original screw would leave a wobble in the turn lever?
                          The light at the end of the tunnel has been turned off.
                          • Gerard F.
                            • June 30, 2004
                            • 3803
                            Donald,
                            That's what I found. The original screw didn't seem to go deep enough into the replacement switch and left the lever with a slight wobble fore and aft. I wound up using slightly shorter (5/8") screw with a lock washer.
                            Could be that on the replacement switch I had, the cam pivot was just tapped shorter than the original. As you will note in the photo in the archived thread, the original screw is a self tapping or self locking screw. But the cam pivot on the replacements are pre-tapped.
                            A shorter screw, and one or two lock washers just works fine for me.
                            Jerry Fuccillo
                            • Ron N.
                              • August 18, 2008
                              • 243
                              Ron,
                              Jerry, thanks for sending the link to the old post. It was a great help. I have a new switch from LIC and tested it by unplugging the installed switch wire harness and plugging in the LIC switch ... brake lights, hazard, tail and directional all worked. Now I'll install the replacement switch.
                              Question - should the plastic connector on the switch wire harness be black or dark brown? My old one (a replacement) is black and the new LIC replacement is dark brown. I can switch to the black one if black is the original color.
                              Ron
