Re: Ethanol - adding fuel to the fire
If you have a frozen slug of water at the bottom of the tank or anywhere else in the fuel supply circuit, alcohol will not likely melt it, but at above freezing, the cosolvent property of alcohol will allow a slug of water to be absorbed uniformly into the fuel, which will purge the water from the fuel system as the fuel is consumed, and that will prevent the slug from freezing and blocking fuel flow when the temperature drops below freezing.
That's how Drygas, Heet, and similar alcohol based products purged water from the fuel system.
